Critique new build
CoRPS
Motherboard
GIGABYTE GA-M61P-S3
Link
Note: Very negotiable. GIVE ME SUGGESTIONS!
Processor
AMD Athlon 64 X2 3600+ (Retail)
Link
Note: While none of these items are set in stone, this is the one I'm thinking about changing most. It looks like it's the best bang for the buck in the AMD X2 genre, however, for only $50 more I can get a 4400+. Opinions?
Memory
OCZ Platinum 2GB (1GBx2) DDR2 PC6400
Link
Note: Actually thinking about picking up 2 of these, for a total of 4GB. Although, not really sure if I'd actually be using it, or if it would just be for ePen0r. Suggestions?
Video Card
XFX 7300GS 256MB (512MB w/TurboCache)
Link
Note: I'm going to be buying this later, for now, if I use the above motherboard, I'm going to be using the onboard until I can save some more money.
Hard Drive
Maxtor 160GB SATA
Link
Note: I actually already have this. Don't need to purchase it.
At the moment, the only thing I'll be using this machine for is basic internet functions, World of Warcraft, Photoshop and maybe some Source mods. I'd like to think that the above specs are overkill for these dated games, and software, but.. You never know. I'm trying to go with a budget system, the rest of the components (optical drives, PSU, case, mouse/KB) I will be using from my previous build.
Currently using a 2600+, 512MB PC3500 and a really old, shitty HDD with bad sectors. :D
Actually, the RAM comes out to $113.99 after MIR.
As for the budget, I'm not really on a SET budget, but the above mentioned basically is the highest I can go, +/- $100
Also, what's a good motherboard with SLI support. So I can have the ability to go dual video later on.
I'd ditch the maxtor and go for a Seagate or WD.
Do you plan on OC'ing? If so, to what settings? I'd get the G.Skill instead of waiting for that OCZ rebate (yes, I know I have two OCZ kits listed in my sig... but I've used G.Skill too, and they're great).
Don't bother with the 7300GS... go for the 7600GT. The 7300GT is great, but overpriced.
SLI? what size monitor do you have? or plan to have?
@enginurd: I don't plan on OCing. I've gotten over that with my old Mobile 2400+ processor I had back in the day. As for the Seagate/WD thing, I actually think the HDD I have sitting around is a Seagate. It's been a while since I looked at it. (Bought it a bunch of months ago, then realized that my POS motherboard doesn't support SATA, long embarrassing story) Either way, I won't be buying a new one, it's still in it's static packaging.
As for the SLI, I may be wrong but I figured the SLI thing was just to get better graphics and performance. I actually run an old piece of garbage Viewsonic 17" LCD. I don't plan on updating it, I don't have the $
No need for SLI then if you're just going to use a 17in CRT. SLI is only worth it if you're gaming on a 22+ inch monitor.
If you're not OC'ing, go for cheaper ram. Theres some DDR2-667 sticks at the egg for $90. Though performance scales well with ram speed on the am2 platform, the 3600+ has not only an odd multiplier, but its also half stepped, making it hard to fully utilize DDR2-800 ram.
Don't bother picking up 4Gb of RAM if you're not going to use a 64bit OS because 32bit OS's can only see and use about 3GB of RAM.
I've been reading in the OS forum that it's actually 4GB that it can access. The reason that no one sees the full 4GB from a 32bit OS is because vista will take into account your video memory first. So for example, my 320mb of video ram is subracted from the 4GB total, giving me about 3.6 - 3.7GB of addressable memory. When I right click
My computer and go to properties on vista ultimate, I actually do see 3.6__ of memory.
I do plan on upgrading to 64 bit to take full advantage of those 4 GBs however.
