Critique My Pre-Penryn Build!! :)
ThR!LL
Well here's some info. I'm getting every part that I will use for when I do get my Penryn processors (except the processor obviously). Some parts I will be recycling from my old build are my case, monitor, optical drives, floppy drive :eek:, and my soundcard. I will be overclocking this rig before and after Penryn. I plan on getting this rig around New Years. Well enough of this, time to get to the build :D
Intel E2160 - $81.99
Abit IP35 Pro - $179.50
2GB Crucial Ballistix DDR2 800 - $89.99
Evga 8800GT KO - $309.99
Western Digital WD3200AAKS
- $71.90
Corsair HX620 - $139.99
Total without shipping = $873.36
I want to try to keep it round this budget. I don't wanna hit over 950.
And as for the after stock HS I'm still thinking about it since I'm not sure if a Thermalright Ultra-120 Extreme will fit in my Cooler Master Ammo 533 case.
Would you guys recommend the E2160 over t he E4400 for a temporary processor while I wait for Penryn prices to drop.
I'd say get the E2160 since you're planning on upgrading to Penryn pretty soon anyway. Hell drop down the E2140 even if you want to save some more cash:
Intel Pentium Dual Core E2140 CPU - $69
Other than that, nice build! Have fun with it!
Does anybody know if the Ultra 120 extreme will fit in my Cooler Master Ammo 533 Mid Tower case?
This build can handle some cod4 action right? I don't need it to be on full settings I just want it flawlessly smooth gameplay on a mid resolution.
Oh wow. I'm used to playing the first cod competetively and I used 1024. This changes everything. Thanks a lot!
But what about my processor?
It shouldn't bottleneck your system too much. It should provide acceptable performance.
I play COD4 on my 4400+ with an 8800GT at 1680x1050 with everything set to max and it runs GREAT.
Nice build. I agree with the E2140 Danny mentioned. I'm still mad that those sticks are so cheap without rebate now... I'm still waiting for my rebate on my 4th set, lol.
