cougarsoccer
- Oct 31, 2006
i just had my 21 birthday and i was looking to build another computer with some of the money i had saved up. let me know what you guys think. also if you have any other items that might give me more bang for the buck then let me know.
Here is the updates on the questions and the links below are the parts
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? fps gaming and a bunch of rts games. i want dow2 to look good
2) What's your budget? Are tax and shipping included?no more than 800
3) Where do you live?mississippi, US
4) What exact parts do you need for that budget? cpu, ram, motherboard, video card, and power supply
5) If reusing any parts, what parts will you be reusing? westerdigital 300 gb hard drive connects sata., a lightscribe cd/dvd drive, and i'm gonna put it in an old full tower atx case for the moment
6) Will you be overclocking? most likely no but i may mess around
7) What size monitor do you have and/or plan to have?19 inch lcd
8) When do you plan on building/buying the PC?here in the next week if possible
9) What features do you need in a motherboard? PCI express x16 2.0
10) Do you already have a legit and reusable/transferable OS key/license?yes i have a legit windows xp home key and a vista ultimate upgrade key
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.182239
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130434
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
i know there is not a hard drive up here. i'm just gonna my 300 gb one in there
let me know about your advice guys. i would like to be able to play some of the newer games. cause i never got to experience crysis either
