Criticize my replacement proposal.
Kaitian
I'm replacing my main machine which it's way dated. I'm planning to purchase on Amazon with their 12 month 0% financing program when paid in full.
My current set up:
Phenom 9950
MSI K9A2 Platinum
Kingston HyperX 4GB (2x2GB)
Gigabyte Radeon 6950 1GB
Western Digital Raptor 300GB
2x Western Digital 1TB Black
2x 22" Samsung 2243BWX
Some old Chieftec Full Tower case which I want to dump it.
Antec 850W PSU
Proposed setup:
i5-4690K http://www.amazon.com/dp/B00KPRWB9G/colid=11BPM93YRDUR4&coliid=I2634GQLSL9HXN
Corsair H110 http://www.amazon.com/dp/B00B4OCW7K/colid=11BPM93YRDUR4&coliid=I2YX9H8FVPMCT7
ASUS Maximus VII Hero http://www.amazon.com/dp/B00K2MASE4/colid=11BPM93YRDUR4&coliid=I18U7UNK8MWFD2
Corsair Obsidian 550D http://www.amazon.com/dp/B006L6ZSWC/colid=11BPM93YRDUR4&coliid=I3FNG1176W6KXR
Corsair CX 500W http://www.amazon.com/dp/B00ALK3HF4/colid=11BPM93YRDUR4&coliid=I1IRRCFAC6S0WQ&psc=1
XFX R9 280 http://www.amazon.com/dp/B00ISSSPLM/colid=11BPM93YRDUR4&coliid=I1YCQJIOOVU40V
Samsung 840 Pro Series 256GB http://www.amazon.com/dp/B009NB8WRU/colid=11BPM93YRDUR4&coliid=I2BH7G31BOBLNS&psc=1
2x Western Digital 2TB Black http://www.amazon.com/dp/B00FJRS628/colid=11BPM93YRDUR4&coliid=I199HZVK072DW7&psc=1
Corsair Vengeance Blue 16GB DDR3 1600 (4x4GB) http://www.amazon.com/dp/B0058J1QYC/colid=11BPM93YRDUR4&coliid=I1JVFR6X0U20P8
Monitors:
2x Asus PA248Q http://www.amazon.com/dp/B008DWH00K/colid=11BPM93YRDUR4&coliid=I2BKPPKQASM2RG or perhaps 2x Dell U2412M http://www.amazon.com/dp/B005JN9310/colid=11BPM93YRDUR4&coliid=I10914AGRWWI09?
Gaming / Everyday use / work / etc
Not really concerned with a budget
Charleston SC
CPU, Mobo, Video card, Memory, case, cooling solution, hard drives (primary & secondary), monitors
Nope. Probably will be giving the old set up to a family member of mine.
6) Will you be overclocking?
Nope.
2x 2243BWX @ 1600x1050
Probably within the next month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Uhh don't really care.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Windows 8.1 64-bit
Your proposed setup is not that good. You've managed to go both overkill and cheap on some of the parts Let's break it down:
CPU
: You've stated that you're not overclocking. As such, there's no reason for you to get the overclock capable Core i5 4690K in your situation besides "let's waste money". You'll be fine with the cheaper Core i5 4590 (no it's not worth spending $30 for a 200Mhz clock speed increase unless again "let's waste money"):
$200 - Intel Core i5-4590 CPU
Motherboard: Again, you're not overclocking. Nor did you mention anything in your response to question 9 that would indicate that motherboard would be a solid choice for you. Based on the information you've provided so far, you'll be fine with this motherboard:
$88 - Gigabyte GA-H97M-D3H Intel H97M mATX Motherboard
HSF: Again, you're not overclocking. Nor is that cooler particularly quiet. If you were aiming for low noise and good cooling, I would go with this HSF:
$71 - Noctua NH-D14 120mm and 140mm HSF
If you wanted bang for the buck regardless of the cooling, I recommend this HSF:
$50 - Cooler Master Seidon 120V Liquid Cooling System
PSU: You really cheaped out here. I recommend this quieter and significantly higher quality PSU for $25 more:
$80 - Seasonic G Series SSR-550RM 550W Modular PSU
HDD: IMO, outside of extreme high performance situations, Black drives are not worth the money IMO. I'd rather have more storage space:
$103 - Seagate Barracuda ST3000DM001 3TB 7200RPM SATA 6.0Gb/s Hard Drive
RAM: That RAM is really overpriced for what it is. I recommend getting two sticks of the generally more reliable Kingston RAM:
$74 - Kingston HyperX FURY HX316C10F/8 8GB DDR3 1600 RAM
No, dual channel performance isn't noticeable enough to justify an extra $10 let alone $28 to $30 in this case.
Video Card: With the money you have saved from the CPU, mobo, and HSF change, you can go with a significantly faster video card like the GTX 970 (if you can find one in stock) or the R9 290.
