jonneymendoza
- Sep 11, 2004
O man I realy dont know where to start. I have such a big problem and I dont know if you guys could help me out on it 
It all started when I switched motherboards for a new northwood processor I got yesterday.
The previous setup was this:
Intel Pentium 4 2.8 400mhz
An MSI MS-6526 micro atx mainboard
2x 512mb corsair ddr memory
9800 pro graphics card
Windows xp pro with sp1
An LG CD-RW 52x
A RICOH combo CD-RW with DVD rom
Western digital IDE 200GB hard drive
PCI soundblaster soundcard(the cheap one)
The setup I have now:
Same has above but with a
intel Pentium 4 3.2 northwood
Gigabyte GA-8IPE1000-G motherboard
Ok I will start from the top to buttom.. i have recently read here in this forum that when u change mobo, it is a common practise to re-install the OS again because of chipset incompatibility. My old mobo has a older chipset. Anyways the guide said that there is no need to re install the OS. Instead there are other methods such has using sysprep or running a repair on the OS. Using sysprep is suppose to be faster to use than the other method.
Ok to speed things up a little bit, I used the sysprep program and followed the instruction rite down the bone and when I changed and installed my new mobo with processor, all the problems began to happen. When I first boot up I had to re install some of my drivers but after that I had serious problems. My windows xp kept shutting down on its own, critical errors where happening and I couldnt even do no last minute backups has it just kept crashing all the time. I would take note on the errors but there too many. Anyways I decided to do the unthinkable. Reformat and partition my HDD  I had lost some of my stuff in the process because the last time I backed up my stuff was just under a week ago!
Anywaz whilst in the process of installing the installation files for xp, it than told me that it cannot find curtain files from my xp pro cd!!! I never had this problem before, I have 2 copies of xp and there not scratched or anything. I managed to resolve this by just pressing enter to try and find the file and continue and it did continue, it did this a couple of times eventually I refomrated and installed xp again, when I installed al the chipset drivers and stuff for my mobo, it crashed and said a windows xp file is missing and cant boot the OS at al!!! I than tried 2 partition and format again and once I entered my cd key 2 begin installing xp, a blue screen comes up like half way through installation, saying thatthere is something wrong with my ntfs.sys file with it saying page_fault_in_nonpaged_area!!!
Im wondering, is my hard drive fucked?? How do I enter ms dos to type a command to fix or find problems with my hard drive?? What is the command 2 do this? By the way I can only use 137gb out of 200gb when I partition and install xp!!!
Hope you guys can help, thx!!
An LG CD-RW 52x
