I just purchased the MSI A75IA-E53 mini-itx FM2 motherboard and almost fried the motherboard while looking around the bios. Here's what happened:
After installing an A10-5700 apu and 8gb of 1866 ram, I went into the bios to make sure the ram was running at the correct speed and make a few adjustments. As I was doing this the bios temperature reading was steadily climbing from about 40 degrees to over 70 degrees. And this was just looking around, not overclocking or anything.
Once I exited the bios and was running windows the temps went back down to the 40 degree range.
I know the ASRock mini itx board has a problem using a lot of power in the bios but I didn't know MSI has a problem there either.
Anyone else have this board and running into this issue?
