Crazy problem with wierd build up on board.
mukow
I have a system now that has chewed up a few motherboards. It worked fine at first then gave a cpu error. After finding it was the motherboard i replaced it only to have the same thing happen again. I noticed the backs of the boards looked a little dirty and took a closer look at the case. There were several small metal shavings in the case. I wiped the case out and replaced the motherboard and things went fine for about to weeks. Now the motherboard has stopped working again, and now there is more crap on the back of the motherboard. It looks like a chemical gunk buildup of some kind. I tried using some contact cleaner, but it can only get rid of this gunk if i scrub gently, like with a paper towel. Does anyone know where this crap would come from? It was around the memory on the underside of the motherboard. I can send that board back, but i don't want to put another motherboard in that case. Does anyone know where it could be coming from? Thanks.
Is it a cheap case? Maybe the minor fan vibrations on the board and the screws are causing the mounting holes to wear? Picture might help.
The case is a Raidmax case and I have put computers in dozens and dozens of these cases and haven't had a problem. The wierd gunk that i found on the motherboard was not actually on the case anywhere that i could see. One of the times I even used different mounts and over did the spacers in an attempt to make sure it didn't kill another board. There is nothing out of the ordinary with the case at all. It looks the same as every other case I've used from Raidmax, and that is somewhere around 80-100+ systems.
Maybe it has something to do with the area the computer is in? You dont happen to run your computer near a mcdonalds or something? lol...
