I've noticed a difference in the cpu voltage lately and don't know if this is normal or not. It is set to 1.3v in the bios as Everest shows. However it will idle between 1.216 - 1.232v and then drop to between 1.122 - 1.138v wile running Orthos. Both cpu-z and pc wizzard 2008 give the same readings. I let it run for 2.5 hrs and it didn't crash at the lower voltage, but why is it lower? Shouldn't it be showing the 1.3v it is set for? Or am I not understanding something? I'm working with the comp in my sig.
