CPU, VGA upgrade
Photoshop, MOH: Airborne, and would eventually like to run GTA IV
$400.00 US, the less money spent the better.
3) Where do you live?
NY
CPU and VGA.
Current Processor is Athlon II X3 435, and Video is Radeon 4550.
motherboardhttp://www.gigabyte.com/products/product-page.aspx?pid=3010#ov
memoryhttp://www.newegg.com/Product/Product.aspx?Item=N82E16820231307
PSUhttp://www.newegg.com/Product/Product.aspx?Item=N82E16817139001
bunch of HDD's
CM centurion 590
6) Will you be overclocking?
no
I still have a Lacie electron blue 19" win 7 set the resolution at 1600 x 1200, but I'm playing MOH at 1024 x 768.
this week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
no
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yep, currently running Win 7
The current resolution for MOH is ok, it only lags when smoke and fire appears on the screen.
I've also checked windows task manager and the game utilizes 90-100% of all three cores on the Athlon II X3 435, either that or I'm reading it wrong or there's something wrong with my system.
Anyway, I'm hoping that I don't need to replace the PSU. I don't think I need a high performance card for MOH, but for GTA...
I can drive to Microcenter, it's about 40 minutes away, or I can order from Newegg.
I'm thinking about these components.
Phenom II 955
Radeon 5670
5770
Nvidia GTS 450
or possibly a GTX 460
Thanks for all your help folks.
Go for this GPU instead:
$175 - Sapphire Radeon 100315L Radeon HD 6850 1GB PCI-E Video Card
And your choice of the Phenom II 955 is fine.
