CPU Underclocking to half speed on its own?
Kido1986
I have a Shuttle SN21G5 with a 3200+ Venice (rest of rig is in my sig). The multiplier on this CPU keeps cutting down to 5 and running the CPU @ 1Ghz. The only way to get my system back to 2Ghz is to shut it off for a minute and then reboot. But sometimes it goes back to 1Ghz. My temps are fine, I've triple checked all of my settings in the BIOS (even reset bios and ran with stock config). I've tried manually setting Voltage and Multiplier to 10 in the BIOS (voltage goes down to 1.05v from 1.35 I think the stock Voltage is). I am getting these reads off of CPU-Z but have checked them in other programs and they tell me the same things.
There's no Cool and Quiet on. I've checked every BIOS option I could think of and still nothing.
What is even stranger, my old build did this too but I could get it to run @ 2Ghz for longer periods of time. The old build had different MB, CPU, and Vid. The only thing these 2 share is memory, sound, and HDs. Also, the only build I'm pretty sure did it on my older memory too (old build started with 1GB Gskill and moved to 2GB Corsair).
Please help guys!
It really does sound like a thermal throttling event.
Check the BIOS to see where your alarms are set at. They may have been set too low and that's why this keeps happening.
Or, turn off thermal throttling all together and see if the problem goes away.
There's no thermal throttling option in my bios. Only option is what fan speed to use (since its shuttle and it came with fan). Theres no alarm settings either. Thats why Im at a loss...
hmmm, what about power? Have you tried moving your system to a different circuit in your house? Maybe there is some kind of wierd power problem that is causing your system to act funny.
Well I do have occasional power issues (but thats another smaller issue) with this shuttle but its happened in different locations (160 miles away, different power cord and power strip even). I just dont understand why 2 different builds do the exact same thing.
BTW, if you wanna look through the BIOS to see if you can find something I cant, heres the manual for it
ftp://ftp.shuttle.com/Manuals/en/sn21g5/sn21v10.zip
