CPU temperature?
qroche85
Hello everyone,
I just built my first core 2 duo rig yesterday with abit ip35 pro and e3110. I use AS 5 thermal grease combined with TRUE+s-flex fan for cooling. The weird thing is CPU temperature in BIOS (I monitor in Abit EQ) indicates 127 Celsisu Degree :confused: while my system temperature is only 27 Celsius degree. The other temp (PWN something...) is about 3x celsisu degree. Can anyone tell me what the problem is? :confused: I'll really appreciate.
What CPU are you using? If you have a 45nm CPU, the temps are probably going to be wrong.
