Freezebyte
- Sep 21, 2008
Greetings all, trying to get as much information as I can to build my new rig, my first SFF. I plan on using either the DFI JR P45 J2RS or the Asus P5Q-EM as my mATX board.
This rig will be used for moderate gaming and the typical other uses. I do alot of multitasking and lately my old A64 just can't keep up with running multiple windows of firefox while watching movies, ripping music ect..ect.. so I need a CPU overhaul. I don't do much rendering or processing in photoshop or premiere nor encoding. I also no longer upgrade/replace my PC's like I used to back in my earlier days as I don't game heavily much anymore, so this setup will need to last around 2-3 years before its replaced. I"ll be recycling my 7800GTX OC from my Athlon 64 setup until I can decide what to replace it with a few months down the road.
I plan on intially building the system with 2 gigs of memory to keep runing Windows XP Pro for another few months before I make the switch to Vista, then i'll bump it up to 4gigs.
I've decided i'm going to pass on the Nehalem launch as the available CPU's will be premium priced and its unlikey there will be any decent mATX boards at launch and I want this build completed within the next month time frame wise and I figured a dual or quad Penyrn setup will blow away my old single 3700+ Athlon away.
That being said, I'm think I would like to do the highest FSB possible to give this rig lasting power for the next fear years unless the FSB jumps for these new Intels don't do much to justify the cost increase. I also WILL NOT be overlocking the CPU's as I no longer have the time, patience, will or desire to mess around with it. I value a stable and reliable PC setup now more then being the most lootzz OC badzzs on the web.
I've read the arguments in regards to dual vs quad. It seems the quads comes across as the more future proof CPU as its just a matter of time before more programs and games take advantage of it, much like the naysayers said about single vs dual cores just a few years ago.
Newegg has the 1333mhz FSB Q9400 for $275
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115131 Its a bit more then I wanted to spend, but its pretty close to top of the line without paying a huge amount.
But the popular core 2 duo's are going for screaming prices, but its two less cores and im worried about less future proofing
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
Thanks for your input and advice with what to do.
