Jul 24, 2007 #1 M mis3 Gawd Joined Jul 4, 2000 Messages 827 I plan to build a new PC with the Q6600. I read it somewhere that the G0 stepping will be better. What does this CPU stepping mean? How do I identify a Q6600 with this G0 stepping?
Jul 24, 2007 #2 Xilikon [H]ard|DCer of the Year 2008 2FA Joined Oct 12, 2004 Messages 15,023 A newer stepping mean less TDP, which is less heat and less power so you can get a better headroom for overclocking. To identify a Q6600 with the new stepping, look at sSpec SLACR on the box.
Jul 24, 2007 #3 T troisanh [H]F Junkie 2FA Joined Dec 27, 2005 Messages 9,561 Xilikon said: A newer stepping mean less TDP, which is less heat and less power so you can get a better headroom for overclocking. To identify a Q6600 with the new stepping, look at sSpec SLACR on the box. Click to expand... Thanks for that tidbit, helps me a ton.
