CPU speed fluctuation
slampy
I'm working on a friend's computer, just cleaning it up and adding more memory. it's an AMD Athlon 64 3500+ with 2.20ghz. it had 512mb in already, so I added another 512. that is when I noticed that in the system properties menu where it lists the computers speeds and whatnot, the cpu speed was listed as 990mhz. and I noticed that if I restart and check again will will show it as 1.78ghz, and sometimes show it's native speed 2.20 ghz. so I took out the stick of memory I put in to see if that changes it back. this is when I realized it was not the memory I added because even with the two original sticks in the system, it would still change the speed that was listen in the system properties. according to the BIOS, it is running at 2200mhz which should be the correct 2.20hgz, so I don't understand why it is fluctuating like that. any ideas? thanks.
what's that? it sounds familiar. I too have an Athlon 3500+ but it does not fluctuate like that.
Cool n Quiet is AMD's powersaving utility which dynamically (depending on what the system needs) cranks up and down the CPU frequency by upping and lowering the multiplier. This allows you to maintain low temps, low power usage, and low noise (if you've got temperature controlled fans) when not running the computer at full load.
so unless you install the utility it won't do this, right? I guess that explains why my AMD doesn't, cuz I never installed anything called cool 'n quiet. why would someone want to use that utility? if it brings the cpu down to 990mhz, like I saw on my friends comp, wouldn't that drastically interfere with the processing speed, and ability to multi task or pretty much do anything intensive?
No utility is required. All you have to do is set the power management to "Minimal Power Management" and that turns on Cool N Quiet.
The idea is that when it recognizes that you need more power it ups the multiplier on the fly.
