Gaming, browsing, some editing
$600 or so
3) Where do you live?
Michigan
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Cpu. ram, MB, possibly faster HDD and OS
full ATX case, ATI 4850 1gb, Etasis 750w PSU
6) Will you be overclocking?
Possibly
24" Gateway FPD2485W, 1920x1200, with more ghosting than a haunted house
now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
SLI or Xfire...probably not...was looking at this
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130275
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
On XP now...and need to get to Windows 7 most likely
For CPU and RAM, I was looking at:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231308
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103849
$600 or so
Michigan
Possibly
now
