You might as well upgrade your 460watt PSU. I bet more than likely it's not a good psu. What is the Brand and Model of that 460 watt psu?
Might as well upgrade that PSU. Your budget of $350CAD can get you a decent PSU, Video Card and CPU. The one I mentioned earlier should fit your needs.
The HD 4870 is really cheap for the performance it delivers. And I guess I need the power supply as well...
Thanks.
