CPU/Mobo Combo?
Depends on your definition of "Best".
I just put a Q6600 in the board below with 2 x 1 GB $39 AData (after rebate ram) set the multi to 8 and the FSB to 400 and booted right up at 3.2GHz into the bios on the stock cooler with a 34C reported temp and let it sit for 6 hours. It is kinda cool in the house but the heatsink (fan was forced to 100% speed) never got past barely warm. If I put both boards in the same case with same video card and monitor I bet the machine you could not tell which was which other than by a lucky guess.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128060
If "Best" means expensive, full of features, sure thats a good board, heck it is an excellent board.
( 9 x 380 for 3.42GHz worked like a dream too).
The best board would be one that fits your needs and budget. What do you need and what is your budget?
