CPU Keychain
leSLIe
so i have a couple of old Pentium 3 chips that i want to "convert" to keychains, they are fully functional btw, so i have to drill some holes but those cpus have pins, and i don´t want to remove them cuz they look kinda cool and they are made of gold, bling bling :cool:, so NE1 have some experience drilling CPUs ?
interesting stuff, the thing is i don´t want to remove all the pins :(
If you haven't actually fried a CPU, you don't deserve a keychain made from one ;).
welll.....just off the top of my head i would suggest covering the pin area with an appoxy. this would protect the pins from bending or breaking, but leave them visable.
for my old socket 370 celeron (fried :D ) i just used a thin long nail and lightly tapped on it until it went through.
Make the GPU you fried into a key chain. That would be cooler, and I'm sure someone could use those P3 chips.
i´ve been thinking about that, it was a Geforce 1 DDR, i lapped the gpu, so there is no GeForce on it anymore.:( i have a Riva 128 though
so i have a couple of old Pentium 3 chips... they are fully functional btw...
So, can I have one? :D
Heh, I was like, that wouldn't feel too good in your pocket... then I realized it was you posting. But like the Devil said, the pins could break off quite easily, even in a purse. BTW, the link Danny posted said to use diamond tipped drill bits for drilling ceramic... and go slowly.
hehehe, well i´m gonna put a keychain to them and put them on my backpack to show off the "GOLD" :cool:, i usually don´t carry a purse, but when i do i wouldn´t like the feeling of the pins everytime i put my hand in it.
