CPU Gamer: The final Choice
Rikus78
- Energy Antec 620 High Current Gamer 620W: 77 Euros
http://www.pccomponentes.com/antec_hcg_620_high_current_gamer_620w.html
- M.B. Asus P8Z77-V LK: 132 Euros
http://www.pccomponentes.com/asus_p8z77_v_lk.html
- CPU Intel 2500K: 196 Euros
http://www.pccomponentes.com/intel_core_i5_2500k_3_3ghz_box_socket_1155.html
- Cooler Master Hyper 212 EVO: 30 Euros
http://www.pccomponentes.com/cooler_master_hyper_212_evo.html
- RAM G.Skill Ares DDR3 1600 PC3-12800 8GB 2x4GB CL9: 39 Euros
http://www.pccomponentes.com/g_skill_ares_ddr3_1600_pc3_12800_8gb_2x4gb_cl9.html
- HD Seagate Barracuda 7200.14 2TB SATA3 64MB: 92 Euros
http://www.pccomponentes.com/seagate_barracuda_7200_14_2tb_sata3_64mb.html
TOTAL: 77 + 132 + 196 + 30 + 39 + 92 = 566 Euros
As you can see the price doesn´t include the graphic card, i have it. It´s a MSI Twin Frozen II GTX 560 Ti
The computer will work at 4.300 mhz and lot of days 24 hours
What do you think? will you change something?
Greetings
Please answer the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you better.
I´m sorry, here i go:
Gaming
650 Euros tax included
South of Spain (Cadiz)
Power suplly, main board, cpu and cooler, ram, hd
MSI Twin Frozen II GTX 560 Ti and a DVD Pioneer
6) Will you be overclocking?
4.300 mhz
7) 7) What is the max resolution of your monitor? What size is it?
Actual 22" 1680x1050 but i´m looking for a 27" 1920x1080
Next week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Only USB 3.0 and SATA 6Gb/s. -----> No raid, never crossfire or sli, no firewire, no esata
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I use Windows 7 Home Premium 64 bits
Thank you very much
Greetings
What case will you be using?
BTW your mobo name and link don't match: The link is for the Asus P8Z77-V LK, not the LE. Though I'd recommend the LK anyway over the LE.
I'd try to get a used p8p67 pro or something..something 8+2 phase with heatsinked vrms..
just for durability.Eh..hate to admit t..but the AsRock z68 pro3-m would be good.
Yes I agree with the above sentiment about z68 or p67. I wouldn't use sandy bridge with a z77 motherboard. Too many gotchas regarding pci-e lanes and how they are used etc. Definatley switch to a p67 or z68 board and you'll be much better off.
I would get a new case considering that case is fairly inadequate for a heavily overclocked CPU these days.I would look at the NZXT Source 210 Elite or Coolermaster HAF 912 as budget replacements. If you want something higher-end, the Corsair 300R and 400R are good choices as well. Either way, replace that case with something more modern, has better cable management, better cooling, etc.
I would stick with Z77. I see no good reason to go with the older Z68 or P67 motherboards.
A 2500K in a Z77 may cause problems?
Greetings
You won't have any problems with using an i5-2500K on a Z77 board. However, Sandy Bridge supports PCI Express (PCI-E) 2.x whereas Ivy Bridge (e.g., i5-3570K) supports PCI-E 3.0.
I recommend the i5-3570K over the i5-2500K, especially if you're going with a Z77 motherboard and the price of the i5-3570K is around the same price as (if not a bit cheaper than) the i5-2500K.
