MirageMobile
- Jan 22, 2007
Hey,
I am having issues with the fan controller of a Tuniq Tower 120 and my Abit IP35-pro mobo.
I seem to lose complete control of my fan controller on my Tuniq Tower 120 at times.
Using a few mobo utilities (uguru and CPUID), it reads the fan at ~1500rpm when the controller is turned up and ~700rpm when turned down.
Yet, when I begin a CPU stress test, I can hear the fan spool up and I looked to see the CPU fan adjusting towards ~2500rpm.
HOWEVER, this is not always the case, as sometimes I am able to fully adjust the CPU fan speed from 700-2500rpm just using the fan control knob.
I have tried this with the "thermal mangagement control" enabled and disabled and have received bost results in both settings.
Now, I have BIOS 3/18/2008
BIOS ID:16
1. Update AHCI ROM version.
2. Update CPU Micro code.
3. Enhanced 45nm CPU compatibility.
4. Fixed C1E function abnormality.
5. Fixed Quick Power On Self Test function abnormality.
6. BIOS compiled date: 03/18/2008.
and there is an update
BIOS ID:17
1. Fixed 45nm CPU compatibility and support CPU half multiplier.
2. Fixed the Wake Up by WAKE# of PCIe function abnormality.
3. Fixed system hang when used Intel PXE CPU series.
4. Fixed CPU temperature abnormality when S3 return.
5. BIOS compiled date: 05/26/2008.
This is the only thing I can think of to try next, but would appreciate comments from you guys.
Thanks.
BIOS ID:16
BIOS ID:17
Thanks.
