I have the Gigabyte EP45-UD3P /F8 Bios/ e8500 CPU
I have been using it for the last couple months just fine @ 4009mhz = 9.5x422 @ 1.23125v in bios which is 1.2v in cpuz ver 1.50. The only other thing besides Vcore that needed to be adjusted to be 100% stable at 4009mhz was mch core which had to be 1.16v, everything else was set to normal.
Today I wanted to see what this cpu/mobo could do and so I started going higher.
I was testing out 4408mhz = 464x9.5 @ 1.38125 cpu vcore, cpu pll 1.63, cpu vtt 1.34.
It was on prime 95 for a couple hours with no errors and so I wanted to see if I could lower some voltages for better temps...but first I wanted to see what "auto" voltages the board would set everything to with this 4408mhz speed. I went into the bios and set all cpu configs options at the bottom to "auto".
From this point forward I did several reboots and adjustments from gigabytes easytune6.
I have CPUZ load up on boot just to verify speed/core voltage and several boots later I notice that cpuz is displaying Core VID (1.25v) and not Core Volatage.... but the 4400mhz overclock is there and stable. I load up speedfan and check the voltages there and it says my vcore is 4.1V! So I quickly shut down and go into the bios to check the Vcore under system stats...it says Vcore is 4.1V!! How is this even possible? Wouldnt the cpu just burst? (The mobo wont even let me adjust it that high) It doesnt matter what I manually set the vcore to because it still always comes out to 4.1v.
I shutdown and cleared the cmos...still 4.1V, I then pulled out my cpu, cleared the cmos and even took out the cmos battery...put everything back in and reboot. loaded optimized settings, reboot, bios still reads Cpu Vcore @ 4.1v!
Now get this, I got the Q6600 out of my other system and put it in the UD3P.
It is coming up with the same Cpu Vcore of 4.1volts!
I reflashed the bios to the original F6 version and Im still getting the same 4.1V cpu Vcore.
I have no idea what could be going on here.
Im not quite sure if the Cpu Vcore is Really 4.1v because If it was really that high then I dont even think the system could boot (it boots into windows and runs just fine)
Anyone have any ideas on whats going on and what I can do to fix this?
Thanks in advance
__________________
Thanks in advance
__________________
