Flogger23m
- Jun 19, 2009
I am currently using a Xigmatek LOKI 92mm fan for my AM2+ motherboard/AMD 965. It works nicely, though as of late the fan has been making some noises. 92mm PWM replacement fans seem to go for $16 or so. I figured I would rather spend $15 or so more and get a 120mm cooler.
My price range is $30-40. I can go a little higher than that if needed. I would prefer a 120mm that is quiet. It must have PWM to automatically adjust fan speed. I would also like for it to push the hot air into the rear exhaust fan of my case. The ability to add a second fan for a push/pull set up would be nice as well.
CPU is at stock speeds, though I plan on upgrading to an Intel CPU sometime in the future so a heatsink that has mounts for both AM2+ and Intel sockets would be ideal.
So far I found the following:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
The product page lists AM3+ support. I assume this means it will work on AM2+ as well?
I am also looking at the Xigmatek Gaia, though if their fan life is short I would prefer a different brand:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233082
Are there any other heatsink/fans I should be looking at?
