Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
use the half height Intel ones. Unless if you are overclocking. Then the Zalman 700 (the CPU version of the VF900 GPU cooler) is just only as tall as a dual slot (about 1.4 inches).
