CPU around 20 degrees....is that right ?
Naxel
Well I was looking at my temperatures to make sure everything is running safely, my gpu was around 60 witch was ok, but when I looked at my cpu I was surprised to see that it was running around 20 degrees idle, and MAX 30 degrees playing hl2 full detail :eek: . Is that normal, me only having stock cooling and all ? or is my sensor buggered ?
I am going to say that the reading that your getting is WRONG! I bet you with a (maybe) a BIOS update, the sensor might read more accuratly.....
If you're 3000+ isnt overclocked, it should run cool, but Ive never seen one run that cool. The usually idle around high 20's to low 30's if im not mistaken. Keep in mind, that 20C is 68F. Theres no way your processor can be cooler than the ambient air around it. Unless your house is below 68F, your temp sensor is giving you incorrect readings.
My temp sensor reports between 12C and 15C idle, 17C to 18C load
I don't know what the heck my BIOS is thinking...maybe I have to add the ambient temp of 35C?
bah
bah
hahaha....your CPU works as a refrigerator!! :D
well thats what it says *lol @ refrigerator* :p I'll try update my bios but I think it is fully updated
my venice core w/ xp-120(lapped) and nexus 120mm(undervolted to 7v) runs at 27C full load and around 22-23C in GA.... so if you live in the north, i'd find that believable
I don't overclock of course.. and my case is well ventilated as far as i know
Here is the big question. What is the room temperature? You cant EVER get lower than room temperature with a plain heatsink and fan. Just dosent work that way. If it did people wouldnt have to bother with complicated compressors and such to cool things.
lol well my phone says that it is 20 degrees *5140* :p and my cpu at the moment is 24 degrees BTW just updated the bios to latest version... maybe it was only 4 degrees off :p 20-24
I wish my rig saw those temps.
Damnit I hate how hot computers make my room.
What do Foxconn motherboard usually report? Are they historically pretty accurate? DFI seems to report a little lower than normal, and Abit a little higher than normal, so just wondering what Foxconn usually reports.
But if you're not OCing a Venice that is only running 1.8Ghz, you're probably not running very hot at all. I'd be interested to see what kind of Prime95 load temps you get on your CPU. If it jumps to the mid-30's say, I'd be more likely to say that your temps are ok.
umm, just feel your heatsink. if its not incredibly hot. then its fine. that's what I would do.
