CPU and/or GPU upgrade options
Black-Tom
Hey all,
I'm looking to upgrade my rig to make it a little more "current" for gaming and specifically Battlefield 3, Bad Company 2 and Starcraft 2.
I currently have the rig in my sig, and for the specifics:
AMD Athlon II X2 245 Regor 2.9GHz Socket AM3 65W Dual-Core @ 3.4ghz
ASUS M4A785TD-V EVO AM3 AMD 785G HDMI ATX AMD Motherboard
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
ASUS GeForce 9600 GSO 512MB 128-bit
Basically what I'm looking at is upgrading my cpu to a quad core am3, and getting a more current GPU. I am looking at getting an ATI/AMD GPU because I wanted it to be more compatible with my motherboard for temp readings, etc. If there's a much better nvidia card then I wouldn't have any qualms about getting it instead.
What I have picked so far:
SAPPHIRE 100338L Radeon HD 6770 1GB 128-bit GDDR5 $130
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102941
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz $120
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
I am looking to buy now, next week, week after, whenever the best deals will be. I would like to spend around 200-250 dollars total. Preferably Newegg, but I'll be happy with Tigerdirect as well.
Any suggestions?
Thanks!
Whoops, totally meant to list that earlier.
Antec earthwatts EA500 500W Continuous Power ATX12V v2.2 80 PLUS Certified Active PFC "Compatible with Core i7/Core i5" Power Supply
+3.3V@25A, +5V@24A, +12V1@22A, +12V2@22A, -12V@0.8A, +5VSB@2.5A
I bought it 1/14/2009
Thanks guys, I appreciate the help. I went ahead and picked up the x4 925 2.8 Deneb, going to think about the GPU for just a bit longer.
