cpu and motherboard please help
ripo66
Hello dear friends
I do not understand so deeply so if you can help me I will be grateful
I'm new here and also sorry in advance for my English..
I have a number of motherboards And number of processors (attachd in the list below)
I want to assemble and build from the list 3 computers I would be happy if you could please help me with the the right and strongest combination
number one 1 will be The most powerful (cpu and motherboard)
and so on ....
2nd place
3rd place ( only 3 is enough )
By the way I am aware that the hardware is very old
CPU:
E7500 CORE 2 DUE
E4600 CORE 2 DUE
E2160 PENTIUM
E5400 PENTIUM
E8400 CORE 2 DUE
E5200 PENTIUM
E7400 CORE 2 DUE
E5700 PENTIUM
E2140 PENTIUM
E7200 CORE 2 DUE
Q6600 CORE 2 QUAD
E6750 CORE 2 DUE
motherboard:
INTEL DG41WV
INTEL DG41TY
INTEL DG31PR
INTEL D945GNT
INTEL DQ965GF
INTEL D945GCNL
INTEL D102GGC2
INTEL DP35DP
ASUS -P5KPL-AM
ASUS P5LD2-SE
ACER -EG31M
MSI 7346 -MS P-6-N SLI V2
GIGABYTE GA-P35-DS4
GIGABYTE GA-945GCMX-S2
GIGABYTE GA-P31-DS3L
GIGABYTE GA-G31M-S2L
GIGABYTE GA EP-43UD3L
By the way if there is support dual channel RAM performance i think it will be great !
Thanks in advance everyone
I would say:
1). Q6600 + Gigabyte GA EP-43UD3L
2). E8400 + Gigabyte GA P35-DS4
3). E7500 + Intel DP35DP
I tend to agree with kirbyrj. But theoretically it may not be so easy to answer a question like yours. The reason is it depends on the intended use for the computer. Some CPUs will be be stronger when running games but not as strong as another when doing a different task such as rendering video.
Hey
kirbyrj and
trent51
thanks for the reply
are you sure that is better to put the Intel DP35DP instead of INTEL DG41TY
(i mean by the chipset older or newer )
and what your think about E7500 vs E6750
E7500 with higher base frequency (2.93Ghz )
but the E6750 has larger L2 cache (4mb vs 3mb).
thanks guys
