Could a bad power supply cause this?
Igg
Right now I'm having some texture corruption and video card related crash with both the Radeon 4870, GTX260 and 8800GT.
No matter what card I use I get texture corruption with NVIDIA like this screen shot.
Or with the ATI card,the driver was good enough to recover from whatever errors but will eventualyl lose signal and go blank, forcing a reset.
I'm suspecting the PSU because when I plugged in my wife's OCZ 800Watt, everything runs peachy.
So what do you guys think?
Im inclined to agree about a power supply problem, I had similar problems when I (nearly fataly) discovered my power supply was on the way out. I noticed my fans had stopped, just in time before things heated up. I discovered a 12V power loss. My general rule is, if things start going wrong for no reason, suspect the PSU and swap it for a higher, better quality one if possible, 9/10 times its the route of the problem. PSU's are generally the first thing to break down in a computer :)
What PSU are you using now? And what are the specs of your system?
And yes it's possible for the PSU to be the cause.
lots of software glitches can be traced to flaky psus. wierd window's errors , ram issues video issues can betraced back to bad power supplies with unstable voltages.As a lead of a suypport crew at a large company, Iv'e seen a lot of strange issues with programs fixed by replacing the psu, also when a psu does go out it can often take several other components with it, especially motherboards I am planning a new computer build and I am willing to make the psu the most expensive component because everything elsed epends on a stable supply of currentto the various components, leaning towards a BFG unit at the moment.
