Corsair QL 2 sided RGB fans
Discussion in 'Overclocking & Cooling' started by Hokies83, Nov 14, 2019.
  1. Hokies83
    Hokies83 Limp Gawd
    444
    Oct 24, 2010
  2. dvsman
    dvsman 2[H]4U
    2,896
    Dec 2, 2009
    Cool! Was about to pull the trigger on another LL120 set for my 2nd rig. Glad I decided to wait for black friday. I think I'll get these instead and swap out the LL set I have in my main rig.
  3. VanGoghComplex
    VanGoghComplex [H]ard|Gawd
    1,821
    Apr 5, 2016
    Gross. After the underwhelming performance of the LL series, I do not have high hopes.
  4. Zepher
    Zepher [H]ipster Replacement
    17,035
    Sep 29, 2001
    I bet their fans are what keep them in business.
  5. notarat
    notarat [H]ard|Gawd
    1,901
    Mar 28, 2010
    Every time I purchase corsair fans I end up purchasing more Noctua fans to replace them. Especially now so since they started making the Chromax solid black ones. No "bling", just performance.
  6. FearTheCow
    FearTheCow [H]ardness Supreme
    4,794
    May 2, 2006
    I gave up on corsair rgb fans when their 3 pack kit almost caught my pc on fire, pc smelled like burnt wire for a couple weeks after that incident.
  7. beheo2019
    beheo2019 n00b
    42
    Aug 31, 2019
    I jut bought 3 rgb fan same on the h115i platinum and use them as case fan. However, I cant control the rgb light because the rgb cable on the fan is 4 pin. My lightning node pro has only 3 pin. How can I use or buy something to make the rgb on the fan work?
  8. Dark12
    Dark12 [H]ard|Gawd
    1,541
    Dec 13, 2003
    Don't quote me but I think the 4pin are 12v and the 3 pin are 5v.
  9. Zepher
    17,035
    Sep 29, 2001
    You need the rgb fan hub that comes with the single kit or the triple kit, all of the fans RGB headers plug into that and then a cable goes from that to the Lighting Node Pro.
    https://www.corsair.com/us/en/Categ...essories/CORSAIR-RGB-Fan-LED-Hub/p/CO-8950020
    They have a new fan hub/lighting node pro combo that comes with newer fans, can't recall what it's called at the moment.
    it's the Lighting Node Core.
    this video shows the new Lighting Node Core
