TwistedMetalGear
- Jun 19, 2005
Just looking for a few pointers here since the Corsair H70 instructions suck.
I'm assuming it is to be installed in this configuration, with the tubes of the radiator on the bottom:
About the tubes: How flexible are they? They feel pretty damn stiff to me and I'm a bit afraid to bend them too much, but it seems like I have no choice. Can I twist them or are they glued to the connectors?
When you place the cooler into the bracket, how far do you turn it? Does it click into place after catching one notch or what? I'd like to have the Corsair logo facing upright, so it would help if I knew which notch or what angle I need to start at.
Appreciate the help!
