Some very nice rigs in here, especially that one right above^^! I guess I'll post up my 650D rig as well. I love this case, although it will soon be going away in favor of something that can fit more radiators internally and an EATX board. I tried to get new pictures but my camera seems to be broken, the screen just shows green dots and it won't take any pictures.
Heres some that I do have though (I have no idea why the colors look so faded on the first one):
Interesting workaround on the radiator mount. No problems with increased noise or vibrations with the fans sitting right up against the top grill?Well, I was able to get the H100 to fit using push pull in my 650d using the Asus P8Z68 deluxe and Gentle Typhoon AP-15 fans. Using the normal mounting holes in the top of the case there was not room for the 8pin connector to clear the lower fan. I was able to mount the H100 offcenter and further away from the mother board using holes in the grates on the top of the case. In the first one you can see where I mounted the H100. The 8pin clears pretty easily.
Any particular reason you have the PSU pulling case air, instead of through the bottom filter?
Any of you guys with dead fan controllers, we'll gladly replace them.
Out of curiosity, what fans do you guys plug into it? Just the stock fans?
I'd be curious to know if there's some similarity (like if you're all using AP-15s or something).
fan controller x 9000.
This case has a fan controller? (serious question.)
I've been running two AP15s on the H100 controller since the cooler launched and I haven't had any issues as of it, maybe it's too early to tell, but I don't think we should have any problems.I just got this case last week to replace an 800D (long story), and also picked up a H100 to cool the processor. Additionally, I swapped out the three stock corsair fans (minus the 200mm front fan) with some GentleTyphoon 1850rpm fans, put them on the stock fan controller, and have it set to medium.
Is this a good idea? I'm asking because initially, I was reading about how the H100's fan controller was having issues, and now I'm seeing these notes about the 650D's fan controller having issues. After reading this, I ran a quick "tissue" test to see what the airflow was like for the two GT fans on the H100, and I noticed that one of them is barely pushing air through, while the other seems normal. The rear fan, due to no obstructions, is also pushing air through just fine.
Would it be better to just get a separate fan controller like the Sythe Kaze one?
