Redbeard
Official Corsair Rep.
- Nov 3, 2005
The option to install 4 120mm fans or 1 200mm fan would be better I think.
Done.
I asked the same question here in this thread. http://hardforum.com/showthread.php?t=1626499.
Short Version: Flip the top fan to intake for now, then replace it with 2x140mm Thermalright X-Silents. Keep the front fan the way it is.
And from playing with my Corsair 650D today, the top fan/fans look relatively easy to replace, as you don't need to remove bits to get at them. The front fan requires removal of the hard drive trays.
Sweet...... You get shipping fixed yet? if its 30 bucks to the US, Canadas gonna be extremely expensive... Y'all know, we really don't use dogsleds eh?
Thanks man. Do you know any fans that light up that would fit in the case perfectly?![]()
No idea. This is my first desktop ever.
DO keep in mind that the front fan has to be 200mm*20mm, or you'll have to move the hard drive bays over (and at least on mine, run smackdab into the video cards).
With alittle work, You can mount a 180mm fan in front as well.
So I hooked up all the fans to the built-in fan controller, and the top fan doesn't spin. It jerks a little bit right on bootup, but then doesn't spin. Is this expected/normal?
/It does spin when I connect it to the mobo, so it's not that.
I haven't done it yet, but it sounds like your fan is being picky about its startup voltage, and if that were just slightly higher through the controller, it would spin.
Is the top fan spinning if the fan controller is on high? If not, I'd probably mail Corsair; maybe you got a picky fan and they can help you out.
Note, I have no comments on the H100's capabilities yet as I now have to connect all my fans to my mobo to properly test out my system. I do have 2 complaints about the H100 so far though, the molex cable is far too short to be able to really do proper cable management, and the rear mounting plate is pretty flimsy; not a fan of the bolts as some slide too easily and others won't budge, so it's a pain to actually line it up with the back of the mobo.
Ya, agreed, it wasn't the best installation method.
The other thing I found is that 4 of the posts, assuming the ones for LGA2011 wouldn't mount into the back plates screws. They were too thick.
BTW, fantomau, reason I don't use a 3rd party fan controller (of which I already have a Scythe Kaze Master from a previous build), is because I don't want the additional clutter in the case and prefer the clean look that the built in controller already offers. I know the 3rd party is far more flexible, but the one Corsair provides is sufficient for my needs, when it was working at least.
Redbeard, can you let us know if the corsair link is on the water yet? I'm really wanting to try the link with lights out!
Thanks for the update.Corsair Link is undergoing some revisions in beta testing - since it's small, it'll probably not be shipped on the water. We'll just fly units over. We're doing some lengthy hardware tests to make sure this thing works before it's shipped. My guess is late September at this point, unless there's some critical stop-ship stuff we find during the beta test.
Speaking of Lamptron, has anyone mounted an FC5v2 in their 650D?
Does the 650D hold it in properly with its toolless drive bays? I'm thinking of asking for this as a birthday present.
I had a FC5v2 in my 650D and no it doesnt mount unless you use screws since the controllers sides arent very long. I use the FC8 now and love it.
It still goes in ok though.
Are there even places in the case to use screws?
I ordered the fan controller, but now I'm hoping I don't have to be creative in mounting it. Also ordered a Cooler Master Megaflow Red 200mm for the top of the case.
23 (L) x 13 (W) x 26 (H)
I am looking at installing some round feet for the Corsair case.
I was looking at Lian Li's offering
http://coolpc.com/shared/viewProduc...s-amazon.com/images/I/31IMzIfH3IL._SL400_.jpg
I know you can remove the long feet on the 650D but was wondering whether something like this would fit???
Thanks
