Corrupted?
doubleJ
I have a wd2500yd hdd and 2 or 3 times, now, it has lost files.
To give a couple examples...
D:\Mp3 is not accessible.
The file or directory is corrupted and unreadable.
Also, D:\Movies is empty. I was watching movies from it just last night.
There are files that I downloaded over the last week or two (7zip installer, realtek audio drivers, etc...) that show the file in windows explorer, but when I double-click, a command prompt opens and then disappears. Obviously the file is bad.
As I mentioned, this isn't the first time this has happened. I'm thinking that it has happened on a 2x120GB ide raid0, as well. If I back files up, repartition, reformat, and copy everything back then all seems to be well, again.
When I run chkdsk, I get tons of Recovering orphaned file instances.
Recovering orphaned file HACD5B~1.AVI (32666) into directory file 26343.
Recovering orphaned file STEVIE~1 (39809) into directory file 9468.
Recovering orphaned file StevieRayVaughan (39809) into directory file 9468.
CHKDSK is verifying security descriptors (stage 3 of 3)...
Security descriptor verification completed.
Correcting errors in the master file table's (MFT) BITMAP attribute.
Correcting errors in the Volume Bitmap.
Windows has made corrections to the file system.
245111705 KB total disk space.
220158728 KB in 34999 files.
12764 KB in 824 indexes.
0 KB in bad sectors.
123829 KB in use by the system.
65536 KB occupied by the log file.
24816384 KB available on disk.
4096 bytes in each allocation unit.
61277926 total allocation units on disk.
6204096 allocation units available on disk.
What could be causing this to happen? What can I do to keep it from happening? I don't usually have anything super-important on my computer, but it's annoying as crap.
JJ
If it has been happening across multiple drives take a look at your hardware. Do you have any other issues with the computer? Bad RAM can cause filesystem corruption, might not be a bad idea to run memtester on it.
I'll give memtest a try, although I have ran it on other occasions without fail. I have corsair twinx-1024-pc3200-c2.
After running chkdsk, d:\mp3 and d:\movies came back. Some of the files work but most don't. Media player 6.4 gives a Class Factory error.
I'm running some different anti-virus scans, just to be safe, but I don't get virii so I doubt that's the issue.
Mentioning hardware...
I have noticed this on the same mobo (abit is7), but it has been different drives and different drive controllers. Stepping through the possibilities, I'm using a different video card and power supply than before when it happened with the raid0 setup. I stopped using raid0 thinking that was the problem. Seeing this, now restores my hope in raid0. I don't recall if this is the same ram as before or not.
JJ
Edit...
Also, it seems that whenever this happens, data written to the drive after a certain date are the ones corrupted. For instance, I have winrar that I downloaded months ago and it's fine, but 7zip that I downloaded last week is corrupted.
Another problem that I'm seeing is that after chkdsk made the files re-appear, they are linked to the wrong data. There are a couple avi's that play a totally different file's video.
JJ
I noticed when this happens a lot of time it has to do with drivers. Give them a check.
