Correct sequence for using 2x NVME in RAID
kidstechno3
Had an old Z370 board that I got this working on but honestly can't remember how, moved to an X570 and my current setup is:
1TB SSD for Windows Install
Regular 2TB HDD
2x 1TB NVME
Before, I was able to have my 1TB SSD for Windows boot, 2TB HDD for whatever, and then converted my 2x NVME into RAID0 for games.
However, on my new board - whenever I enable RAID and reboot to get access to the AMD Raid utility, my SATA1/2 drives stop showing. Switch back to AHCI and reboot and they work fine.
What's the correct order of this to get this working how I want?
Check your manufacturer motherboard for storage drive compatibility. I like to update latest and greatest motherboard bios firmware and do a clean crispy latest and greatest operating system install.
A lot of motherboards share address space and/or lanes between some of the devices. for example, enabling your second m.2 port may disable SATA ports 2&3, or disable one of your PCIe x1 slots. What motherboard are you attempting this on? It may be that you may need to move your SATA devices to some other ports.
I was just about to mention the lane sharing myself. My current board is the same way. If I use m.2 slot, I lose 2 SATA ports (which Im using all of them).
just an FYI, raid 0 NVMe's are not going to give your games any performance benefits.
Do you want raid0 just to the nice bonus to have them show has a bigger single drive ?
If so, if no solution work with the motherboard and are Windows, you can look at software side solutions (either raid 0 or just combining drive into a single big one):
https://www.windowscentral.com/how-create-one-large-volume-using-multiple-hard-drives-windows-10
If it is only for games, I imagine it could be better/simpler to just combine them without raid0 going on, fast NVME seem to be overkill already over regular SSD on that workload.
Yea I ended up doing a Striped partition in Windows using the 2 formatted NVME drives under Disk Management and it worked like a charm. It's just easier to handle 2 drives as one.
Interesting, is there a max bandwidth that games use?
They seem to hit a ceiling fast enough, the difference between HDD and SSD is really big and than it became very small between raid SSD or nvme:
It depend on the game, maybe it will change in the next year's if decompression (?) with CPU able to reach closer to 100% during load stop being the main bottleneck when you hit regular SSD speed.
