CoreTemp .95 beta crashing 939 nForce4 systems?
CruisD64
restarts 2 of my systems. thought my opty was unstable but i'm thinking its the program now. can anyone else confirm this? check my sig if you have a similar setup and please try it out! thank you!
Funny that you posted this. I also was using CoreTemp and Coretemeter and I felt like it was crashing my system if I had to much temperature programs open--system would just shut off. Not sure if it is the program though.
If I were you I would run an experiment. Just leave computer on and do normal applications without the CoreTemp. Next day or hour...depending on how long you want to test...run CoreTemp. Close out of it, reopen it and see if the system crashes. I would be interested to see the results.
http://www.alcpu.com/forums/viewtopic.php?t=237
Seems like there is definately a noted problem with it though.
I did just that and sure enough, comp restarts. Glad to know that its not my system afterall. I thought i F'ed the processor up when i removed the IHS even though there is no visible damage. With coretemp version .94 things are fine and my maxtemp is 52 using orthos gromacs. Anyways, i'm happy. It always feels good to find the solution to computer problem :)
Thanks to this post, I feel better about my system. I thought my OCing led to my system being unstable even though it passes Orthos and Memtest just fine. I'll just use the older 0.94 for now until the issues get resolved. Thanks again OP! :cool:
does the same to my nf4 ecs kn1 extreme s939 bored. i thot it was becasue of my overclock but it just stuck with .94 and the probs went away
