I think you need to adjust speedfan up by 15 degrees.I am pretty sure that is normal. I think the CPU temp is measuring the Tjunction temperature while the other is actually the cores. Right now speed fan says my cores 1 and 2 are at 19 and 22 while my cpu temp is 42.
Edit: I could easily be wrong though as I am not 100% sure so I would check anyways just to be safe. It may be something to look into though. I am not sure what the cpu temp is actually reading its just a guess.
19c is 66 degrees F. That would be one heck of a cool running CPU, not to mention a really cold room.
