reaper7534!
- Feb 13, 2016
Got it finished today for the most part. Couple little minor things I want to fix and will do that after first coolant change. Mainly the line going from res to cpu block. It's not running parallel with the res and that is driving me insane.
Also need to find some blue memory and paint mine, red is sticking out like a sore thumb. Any thing else you guys thing I could change to improve it ? FYI, it is running about 5c cooler than when I had my Swiftech H240 X2 on it.
System Specs
Intel i7 6700k @ 4.0 Ghz
Asus Z170 S Sabertooth
Asus GTX 1070 Strix 08G
Corsair Vengeance DDR4 3200 Mhz 16 GB
Samsung M.2 950 PRO 256 GB
Samsung 850 EVO SSD 512 GB
WD Black 2 TB HDD
Corsair RMi 850w Modular PSU
Thermaltake Core P5
EK Supremacy EVO Nickle/Plexi CPU block
AlphaCool XT45 420mm X-Flow Radiator
XSPC Photon 270 Reservoir w/ Aluminum motor mount and D5 Vario Pump
Thermaltake Riing 140mm Fans
XSPS 10/14 Tube and fittings
CableMod PSU cable kit
Mayhem's Pastel Blue
I think that is everything. Sometime in the near future I will drop in another GPU for SLI
System Specs
WD Black 2 TB HDD
Thermaltake Core P5
