I will be using this PC for Gaming, Programming, and Web Browsing.
Budget < $2500.00
3) Where do you live?
Rogers, AR
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything except a Monitor.
I will be reusing my 28" Hannspree LCD
6) Will you be overclocking?
Yes
28" (1920x1200)
Within 3 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
RAID and CrossFire
10) Do you already have a legit and reusable/transferable OS key/license?
Will be using Windows 7 64-Bit RC1 until it becomes available to buy.
Here is my Wishlist:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=11516546
Bascially I want a wicked fast PC for gaming and overall general use. I don't need a lot of storage as I already have a 500gb External Hard Drive. This is why I have choosen the 3x30 GB Vertex's for RAID 0 configuration. The only thing that might be changed in my config is the MOBO but that MOBO has gotten a lot of good reviews for exactly the performance that I want. Some of the parts like the memory I have choosen because that is what other users have used on this board to get good overclock results. I know that the G-Skill is cheaper and the voltage is a little lower but I haven't seen anyone use that memory with good overclocks on this board yet. Oh I picked the LG Blueray/HD DVD reader because I have a ton of both Blueray and HD DVD titles.
Let me know what you think about this build Thanks.
Budget < $2500.00
Rogers, AR
Yes
28" (1920x1200)
Within 3 weeks
RAID and CrossFire
