- May 4, 2005
∞Velocitymaster∞;1035398294 said:Ha one more person gets their hands on a 930. Please let us no how much you can oc that on air
I got it at Fry's for $317.17 including 9.75% tax--that's CA for you. Sticker price was $288.99, a full $10 less than Newegg. They're only $249.99 at Microcenter but I'd spend more money on gas and time to get there and back, so I didn't bother.Wonderful... How much?![]()
what's the difference between these and the 920s?
As soon as the rest of my parts arrive I'll definitely see how well I can push the clocks on this beast.
Temps? CPU-Z? s'il vous plaîtI have this beast OC'd to 4.2GHz on air with a TRUE Rev C and Thermalright's Chill Factor go.
No problem: CPU-Z validationTemps? CPU-Z? s'il vous plaît
Picked up the Fry's combo a second time because my 1st one had a banged up MB box. So I have 2 CPUs to test but little time till the weekend to do the build.
Yes, HT is on. Here are my readings using RealTemp and prime95's max-heat setting. For reference TJMax is 100 degrees C.Any is fine. Lust looking for a reference.
Is HT on?
http://img.photobucket.com/albums/v74/clemenceau/RealTemp-sensorTest.png[*/IMG]
I'm pretty new to i7 O/Cs so it seems like it's hot, but it's running stable.[/QUOTE]
That is too hot. Max safe temps should be around 80C, not 99C. That's right up to thermal throttling and/or thermal shut down temps.
Oh sorry, I missed that. Must have been that poor nights sleep.Xeltic -- check post #12. He said that he had overclocked his 930 to 4.2 on TRUE.
Thanks, yes, it's pretty stable. It passes several passes with Memtest86+ 4.00, does SuperPi without incident, and it doesn't crash under prime95. I'm looking into watercooling at the moment.[X]eltic;1035430688 said:That makes the situation slighly less worrisome, but 99°C is still very hot. If your computer is completely stable, you COULD keep these settings, but with extreme temperatures like that you will likely reduce the lifespan of your processor.
I'm using a TRUE rev C with Thermalright's Chill Factor goo, which is pretty great according to HardOCP, and on the Thermalright I have a Noctura NF-P12. I just now disabled the mobo's fan throttling so those should be 100% all the time now. Airflow inside the case is pretty good (lots of 120mm fans, one 140mm fan). Any other tips for keeping the proc cool?
Microcenter has them for $229!!!! great price but the 920 is only $199
Whoa, what city do you live in? Here in Fresno there's 8.75% tax and I thought that was high. (OK, I guess 1% more isn't such a big deal, plus we don't have a Frys anywhere, the closest being in San Jose.) Cool unboxing though.I got it at Fry's for $317.17 including 9.75% tax--that's CA for you. Sticker price was $288.99, a full $10 less than Newegg. They're only $249.99 at Microcenter but I'd spend more money on gas and time to get there and back, so I didn't bother.
West LA, 9.75%.Whoa, what city do you live in? Here in Fresno there's 8.75% tax and I thought that was high. (OK, I guess 1% more isn't such a big deal, plus we don't have a Frys anywhere, the closest being in San Jose.) Cool unboxing though.
I got mine from Fry's, and my batch number is 3001A135.ok I just got my I-930 in today from Amazon. Wont be getting the rest of the parts till the weekend to build. What is a good batch # on these so far? My batch is # 3001A127
