sucks, I hate everytime a new CPU comes out you have to buy new mobo
You dont have to buy a new CPU everyime a new one comes out. Called future proofing. It will be a loooooooooooooooooooooooooooooooooooooooooong time until something can truly best my 3930K.
That's what everyone thought about the i7 920s.
Socket 1150 is basically because this would be the first SOC chip and as mentioned built-in VRM and some more changes, but mostly because broadwell (14nm) would later on use the same socket, so it's almost like future-proofing it from now only.
I'm still running a 920 and it STILL runs everything great...*shrug*
I think pin counts may be more related to power requirements (efficiency) than ability, and Haswell has been designed to be as low-power and efficient as possible. I did a quick comparison between pin counts and max TDP going back a ways for the Desktop Core i7.
Ivy Bridge --> 1155 pins --> 77W
Sandy Bridge --> 1155 pins --> 95W
Sandy Bridge-E --> 2011 pins --> 130W
Gulftown --> 1366 pins --> 130W
Bloomfield --> 1366 pins --> 130W
Lynnfield --> 1156 pins --> 95W
A pin here or there is probably a rebalance of power needs versus data bandwidth if I was guessing.
Via http://en.wikipedia.org/wiki/Intel_Core#Core_i7 (Nahelem core) and http://en.wikipedia.org/wiki/Intel_Core#Core_i7_2 (Sandy Bridge core)
Haswell will not be a true SOC, there still is a separate southbridge.
As for the number of pins... a 5 pin difference is not a significant change. The pin change is probably to help avoid confusion between what works with what, although Haswell-E is supposed to use 2011 pins.
Wow! I give up. I cant keep up with these processors no more.
