Core i3 530 - Dedicated GPU?
JDT
Hi,
I've recently purchased an i3 530 as a budget machine which I will OC, and I realised the chip has onboard graphics. Is there any way to disable them on the i3 and use an external card? A friend is selling me a boxed 9600 GT for $50 and I'd prefer to use that.
Thanks,
JDT
It also depends on the motherboard that you will be putting that i3-530 in. If the i3-530 is installed on a P55 motherboard, you'll need a discrete graphics card anyway since the chipset does not support the i3's integrated graphics capability. But if that CPU is on an H55 or H57 mobo, you may need to disable the onboard graphics capability in the BIOS with the monitor connected to the motherboard's connector before you install the discrete graphics card.
$50 for a used 9600GT? You're friend isn't giving you a deal at all. You can get a better used video card for $50, and for a little more, you can get a GTS250/9800GTX+. That is, if you are gaming, if not, it's not really a big deal.
Board is a P7H55-M Pro: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131623
The integrated graphics are quite slow. And the 9600GT is still in the box unused.
Yeah your "friend" isn't really being a friend at all. Tell him to suck it. You can get a much better card for $50 now-a-days.
500w no worries I checked. I also wanted to know if this would increase CPU performance since the graphics processing is offloaded to the dedicated card?
No offense, but can you tell us what PSU you have anyway? Exact make and model? Just because you say it's a 500W PSU doesn't actually mean that it can actually provide 500W of power. There are many 500W PSUs out there that can barely provide 150W of power let alone 500W. So please find out the exact make and model of your PSU. Otherwise, you're just risking your hardawre on an unknown quality PSU.
No, CPU performance is not increased at all by offloading the GPU processing to a dedicated card. The Core i3 and the dual-core Core i5 CPUs have a built-in GPU solely for GPU processing. As such, the CPU itself does not have to deal with GPU processing at all. You're gonna get the same exact CPU performance with the Core i3 with or without that dedicated separate card.
