Core Duo 2 Chipset
AliP
I'm planning to upgrade my PC as soon as 8800GTX comes, here are my planned specs:
Core Duo 2 E6600 Hopefully overclocked to atleast 3.5ghz with water cooling
8800GTX "Cooling?"
Some big power supply (I'll select it later)
Raptor X 150G
So I need to find a mobo for this rig.
Heres my requirments the ones starred " * " are what id like to have but are not required
PCI-E Sli not required but peferred
2ATA Connectors *
SATA
atleast 1 PCI slot
The mobo must be stable and work with some "Noob" overclocking
775 (Soket T)
I have no idea what type the chipset should be.
I have 3 ATA hard drives, i have a secondary PC for downloading but I'd like it more if it would fit in my primary PC. (All secondary)
So please help me, I've been trying to find one for a while and cant find one so please help me, this is a gaming PC.
Edit: I really like this one, does it fit my requirements? P5N32-SLI SE Deluxe :confused:
Hmm, looks like it dosent oc well.
How about this one: P5W DH Deluxe
Aint i gonna get any proper reply's here?
If you want to do SLI, you're going to need an Nvidia board unless you want to use hacked drivers.
At this point, you should wait for the 680i SLI chipset from Nvidia. The current 590's aren't going to get your 6600 anywhere near 3.5Ghz. As for that specific board mentioned below. Not sure if it's the 590 or not, but if it is, wait for the 680i. Should be out within the week (at least launched, not sure if it's going to be available right away).
I personally have the P5W DH. It's a great board but you need hacked drivers for SLI...should work well with a single 8800GTX though.
Great, the 8800GTX also comes next week (delayed launch) I'll check it out again then, thanks man, you saved me a lot of searching (I've been looking for a good board for a week now)
