Core 2 SLI?
shadowsz14
I'm building a system, and thus far I have all the components except the motherboard. I have been having trouble finding a board that is Core 2 compatible and does SLI. I have a board that is on back order (Asus P5NSLI, nVidia 570), and when I spoke with the customer service at Tiger Direct, the board is nearly a month out from shipping.
Are there any boards out there that support Core 2 Duo as well as SLI? I can't find one that isn't over $200.
Anywhere else have that same Asus board?
I've heard the old SE version of the SLI board with the NF4 Intel does support Conroe with modification.
There are no Conroe mobos with SLI. Current ones are Crossfire only. The one exception is an older 570 ASUS mobo but its not that great for overclocking from what I hear. Forget the model number (its probably the one you mentioned). Basically if you want Conroe/SLI you'll need to wait for the 590 mobos due out in September.
Asus has both the nForce 4 SLI SE and the nForce 570 SLI boards available. The nForce4 based board has the full 16 lanes for each slot with the 570 being newer but only having 8 lanes per slot when in SLI mode.
Nettwerk said:
Im gonna get conroe when a decent sli board is out and it loks like this might do:
http://www.xtremesystems.org/forums/showthread.php?t=113633
better have decent onboard sound though :/
abit + intel :(, havent you learned your lesson?
if you are gaming, you should prolly get a dedicated sound card. you can get one of those auzentech dts connect sound cards for around $100, or one of those cheap ass chaintech VIA Envy24-HT sound cards for like $20.
Last time I checked the IC7-Max3 and IC7-G were some of the best boards you could get for s478.
I would normally chide someone for trying for SLI (or an nVidia card in general) on a Core 2 Duo system, but with AMD's recent buyout of ATI, I suppose the tides are turning. Even an Intel buyout of nVidia isn't out of the question. I have a feeling that very soon we will see Intel chipsets supporting SLI in favor of Crossfire, but that doesn't really help you since you have a system to build now...
Personally, I'd just wait on the board from tigerdirect.
