Coolermaster Elite 120 Advanced
Kaos_Drem
The Cooler Master Elite 120 Advanced is out and available at newegg, not sure if the newegg price is a mistake or not but if it isn't then this is a very affordable and not half bad looking case from CM.
http://www.hardwaresecrets.com/news...-the-Elite-120-Advanced-Mini-ITX-PC-Case/6581
http://www.coolermaster-usa.com/product.php?product_id=3102&product_name=Elite 120 Advanced
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119261
you know, if people are so worried about airflow in this case, they could always install a 200mm fan in the front :p (yes and get rid of all the drive cages, but for $50 who cares if you trash it while modding!)
Not bad, especially at $50 I think I may get it over my planned Prodigy (or, get the Elite 120 and then upgrade later to a Prodigy). :)
This will be my first mini PC case, I watch it closely since CES, and it is almost the perfect case for my goals. (With some modding it will be perfect)
http://www.coolermaster.com/product.php?product_id=6852
Prodig is not good for me, Lian Li ones neither. I was thinking about Shuttles too, because I like them, but the special psu is not my taste.
This CM can handle even biggest VGAs, like 7990 or 690 or previous beasts, Full modular PSU and Corsair H60/80 with some modding.
My plan is a gaming rig with i7 3770k, HD 7970, 16GB memory, HDD+SSD Corsair AX 650 PSU and external DVD -blue-ray combo. But it will take time until I get money for it. I'm waiting for some decent AMD motherboards as well, but I think I will stick with Ivy Bridge...
Again, another case made absurdly large by the inclusion of an optical drive... WTF. It's 2012, people...
I might just get this so I can give it a haircut down to the top of the vid card, get rid of that absurd front panel and rotate the drive cage on its side (5 in 3 style). (Oh, and toss the PSU extender).
i would build this as a gaming HTPC so i would need a Blu-Ray drive and that optical slot is useful for me.
