I have the 690 and am absolutely thrilled and perplexed with the number of fans. The front and rear fans are no-brainers of course. However, there are 2 top fans, 2 side fans and 2 bottom fans. Do you run both top to vent out, 2 side in and 2 bottom in? Some other mix and match? It seems that if I vent the bottom in, it'll just suck alot of dust into the case.
Thanks in advance for your thoughts and advice.
