maverick0817
- May 3, 2009
any recommendations for 140mm fans?
i just ordered the parts for a new build today.
i'm going to have:
Xeon X3440 CPU
Cooler Master Hyper 212+ HSF
Gigabyte GA-P55-UD4P
G.Skill 4GB (2 x 2GB) DDR3 1600
XFX Radeon HD 5770
Seagate Barracuda 7200.12 500GB SATA HDD
Corsair 650TX 650 Watt PSU
Cooler Master 690 Case
does this sound like a good fan configuration for the CM 690? (in terms of airflow and balanced cfm)
there are two things i'm worried about. first, i don't know how well i'll be able to fit a fan in the bottom slot because i didn't buy a modular psu. the cabling coming out of the psu may interfere. second, i'm not sure if both top fans will fit. my hsf may block one or the other.Code:intake: front - yate loon low speed 120mm 44.5cfm bottom - yate loon low speed 140mm 46.0cfm side btm - yate loon low speed 140mm 46.0cfm exhaust: rear - yate loon low speed 120mm 44.5cfm top frnt - yate loon low speed 140mm 46.0cfm top rear - yate loon low speed 140mm 46.0cfm
thoughts? suggestions?
as soon as i get the system built, i'll be sure to throw up some pics, as well as my results with the x3440. newegg sent me a 5750 instead of the 5770 i ordered and i've been waiting forever for the rma to get wrapped up. this little snafu has delayed the entire build by more than two weeks now.I am interested into hearing about your X3440, especially for its ability to go into 4.0GHz. Please post more![]()
I wanna to ask you if is a good idea to mount a 120 mm fan on the place where is the cross in the picture.
What do you think,guys ? It's gonna improve the airflow ( hdd's and graphic card - especially ) ?
http://img204.imageshack.us/content_round.php?page=done&l=img204/4421/cm690.jpg&via=mupload
Please give me some advices. Thanks.
Well, I thought I would add my build to this thread. So here it is.
{/QUOTE]
I am not a fan of OCZ, but damn that memcooler looks sexy in black. I may have to pick that up and paint it too.
Well done!
{/QUOTE]
Well done!
Thanks man!! Ya, I saw a guy that had his powder coated and thought that would be cool in my setup. I didn't want to spend the money on powder coating so I used a Engine enamel to paint the top. Also I had the hardest time finding that cooler because it's an older part. I had to get it from Memoryc.com which is overseas.
Do you guys find when routing the cables in the back, they might get pinched when you put the side panel on? I was worried about that so I cut a little groove for the cables to tuck inside and the structure of the motherboard tray was compromised. Now it's a little floppy
Its such a great case, kinda sad this thread is somewhat dead. The one on overclock.net is still going strong 1435 pages.
