As this is probably going to be my nex case (after a SG05) i'll post some pictures I found:
mannyfc water cooled 240 rad . Source
snip
I don't have any issues with heat buildup and I have a relatively hot GPU that pulls in cool air then dumps the heat into the case. There's enough airflow front to back. I could increase airflow by flipping the PSU so it exhaust the internal air instead of bypassing it like it does now. I'm also not overclocking i3/h77, so if you plan to oc there's that to deal with. I wouldn't use this as a gaming rig without at least h20 on the CPU.
As far as the SFX psu it will definitely fit, but realize the PSU bracket sticks out the back about an inch. Great if you need the room for a full loop. If you want to flush mount it you'll need to fab up a bracket to use the bolt pattern on the back. An SFX adapter is going to cut it.
Here's mine for reference.
xyexz did a great job with a custom full loop
