I currently have a Phenom II 955 and I'd like to push it moderately, let's say 3.6-3.7GHz.
My system has the following components:
- AMD Phenom II X4 955 Rev. C3 (max 95W TDP) at stock speed (3.2GHz).
- MSI 870A-G54 AM3 motherboard (not FX version).
- Kingston 4GB DDR3-1333 RAM (2 DIMMs on Dual Channel mode)
- Arctic Cooling Alpine 64 Pro Rev.2 heatsink (supports up to 90W TDP only) with a 92mm diameter fan.
Now, during summer, my temps are 39ºC at idle and 60-61ºC with Prime 95; during winter, 29ºC at idle and 57-58ºC with Prime 95. So environmental heat it's a problem with this cooler.
I'm looking for an affordable cooler with good performance and restrained size, with a 92mm fan if possible, mainly for aesthetic reasons and easy DIMM handling. I wonder if a cooler with those features exists on the market. I've considered the following:
Thermalright True Spirit 90M
Scythe Katana 4
Zalman CNPS5X Performa
Raijintek Aidos
Xigmatek Loki II
I've read over thirty reviews and still I'm not clear about anything, because most of reviews are for Intel CPUs and coolers with 120mm fans.
What do you recommend? Does a cooler with a 120mm fan but with compact size exist? It must have a height lower than 150-155mm and enough RAM clearance for easy handling as I've said. Note I cannot remove the module located at slot 1, because my mobo does not support it, so RAM clearance is a MUST.
Thank you in advance.
Scythe Katana 4
Raijintek Aidos
Xigmatek Loki II
