Cool n quiet unstable to overclock/underclock?
Hello all,
I have a 3200+ winny
ABIT AN8
Corsair 1G ram
OCZ 450W Mod Stream PS
eVGA 6800GT
With cool n quiet and (uGuru) I can not change ANYTHING even fan settings or it gets unsable and shuts off the computer.
How do I disable this or fix my problem?
I am only getting 31 FPS in IL2/Pacific Fighters and my system is running very HOT in the mid to high 50s while playing that game with stock AMD cooling.
Thanks in advance.
~PW
what are your overclocked settings?
all i really need to know is if you changed the cpu multi or VID from stock ;)
also, you should make sure you have the latest bios for that mobo.
I have all the latest Bios and drivers.
I will get the exact numbers for you tonight when I get home from work.
but as I said, I change ANYTHING and it turns off.
I have a DFI board similar to your Abit one, and while I haven't tried overclocking yet, it says all over the board's documentation that you're not supposed to use cool'n'quiet if you intend to overclock.
under control panel, power options, then change setting from minimal to always on. Can also do google search for how to enable/disable cool n quiet.
Thanks for the help, I will look into it and play with it. I downloaded RMClock and am playing with it right now.
I also have done several 3d Mark 05 runs and my score keeps going down. I was getting 48XX the first few times Stock and never once touch any speeds and now its in the 31XXs. I brought everything back down to stock and I still cant get above 32XX on 3D mark 05
I doubt that has anything to do with C'n'Q though.
In the install for the CnQ software states that there is an issue with the software not ramping the porcessor up like it should in some cases. If software was not fully unistalled your processor may still be running at lower voltage/speed during 3Dmark runs.
perhaps you inadvertantly turned Antialiasing and/or Ansotropic Filtering on in the display control panel? That would explain the drop....
I only have the free version so I have no ability to select that in my 3D mark 05 :(
