Cool BioShock Submerged PC
It was just music, had no info on the audio track, everything you need to know is in text on the video itself. (just in case you were wondering)
Ha- I read "It was just magic" twice... Could not figure out for the life of me why you were so mean.... :rolleyes: Gawd I need to learn to read or somehting.
Oh- as far as the fire hazard of miniral oil- just about none:
Flash point: 135C (275F) CC
Autoignition temperature: 260 - 370C (500 - 698F)
I figure by the flash point, the aquarium will have failed anyway... :eek:
Oil temps can get hot since there is nothing to radiate heat away from the oil, but nowhere near hot enough to spontaneously combust. It just becomes a medium for heat to build up and surround all components -- the oil transfers all heat to everything submerged in the oil.
I have done two mineral oil submerged PCs - the first was about ten years ago. I picked up 20 of the regular sized mineral oil bottles at the grocery store, but they only filled up about half my container. I was too embarassed to go straight back to the store for more, so sent my girlfriend at the time out for another 15 bottles. The clerk at Albertsons asked her if mineral oil was on clearance b/c less than an hour earlier, some guy (me) bought a cart full of oil bottles.
Anyway-- It's neat, but not worth getting oil all over the place. The oil eventually eats into plastics and rubber seals. I had motherboard capacitors fall off their legs both times. I still have one of the USB cables from the first time I tried submerging a motherboard/CPU/video in oil. The cable was bent inside the oil and ten years later is stiff as a rock and still bent in the same shape.
Now that I've seen it, uh..........it's ok.
I guess I was expecting more than a motherboard stuck in a fishtank.
I think the idea is cool, but I'll let other people screw up their rigs by submerging them in mineral oil and other liquids.....
Holy crap. I want to get some hardware and just try this out for the cool factor.
djuniah:
Hey, I thought you made a pretty clean job of it. Alot of submerged PCs tend to look a bit kludged together, but yours looks good.
I especially like the aerator instead of active fans.
Lots better than the one I built in a tupperware bowl :)
Thanks! When i set out to put all of this together, i had a few things in mind. I really wanted it to look clean, and since it was for an HTPC, it needed to be small and minimalistic.
Actually now that I think of it, the aeration is probably better than just circulation. It does offer some cooling ability - though probably not much. More than nothing anyway. It's got to make a mess on the inside of the cover though.......do you find it dripping out at all around the cover's rim?
well, not yet ;)
I did see a drop or two yesterday, so i lowered the oil level a bit so that it's just above the visible area in the front (i actually had it higher than it absolutely needed to be because i just wanted to finish off one of the bottles of oil that i had)
Amazing song AND it was featured in Bioshock. So, you saying it is gay is a personal feeling, but it is definitely NOT pointless.
1920s music in Bioshock? :confused: I never played the game, but I'd think hard rock is more suitable for a video game than something from pre-Depression era.
With a 50's art deco environment, 20's music isn't a hard sell. Todays elevator music is usually 60's - 70's, so the time-line fits.
Again, seeing we're on the "aquarium" thing, I started to think about chillers. I wonder how well a:cool: chiller would cool the oil. There would be less circulation in oil, but if the aeration and chiller was near board, I'll bet some [H] OC'ing could take place.
That's why I'm Picking up an H70 for my Core i7 beasty.
Ahh....but you're talking about a fluid filled chiller for an air environment while I'm talking about a chiller that's for a water environment to cool the oil the motherboard is submerged in.
How soon before we start seeing mobos and other components stamped as oil-submersion-friendly, I wonder...?
Bobby Darin's version of "Beyond the Sea" was recorded in '59. Honestly, if you can't be bothered to even find out that Bioshock is a game with steampunk elements that takes place in 1960, it's probably not worth commenting. (Oh, by the way, it also takes place under the sea, in case you didn't catch that.)
