I have lapped a few CPUs now, first my P4 2.8ghz, which was perfectly flat and worked beautifully after.
The second CPU, which is an e4400 (current rig) was concave by this definition.
So, after some lapping with 400/800/2000 grit sandpaper, I put the CPU back in. To my surprise, I noticed no temp drop at all (with a Scythe Mini Ninja cooler).
My train of thought was, "well, it didn't get worse, so I can't really complain"
Then I read a few things about how to apply AS5, and so I decided to take my CPU out and re-apply AS5. Well, I checked the processor again, and again to my surprise I find that the processor is now convex. I mated the cooler and processor without any paste, to see what the contact was like. Sure enough, there were gaps on the edges as only the middle was making contact. I rotated the processor to make sure it wasn't only one edge, and it was convex no matter which side I looked at it.
So I lap the processor again, this time with only 400/800 grit. No difference. The only thing I can think of is that when I lap the CPU, I don't go over EXACTLY the same path: it varies by a centimeter or two, thus rubbing the edges of the CPU with fresher, raised sandpaper, which ends up sanding them down more.
So I apply my AS5 in a straight line along the cores, fire it up, and what do you know - my temps are now worse by 3 degrees. This is where I sigh. I ordered a Thermalright Ultra 120 Extreme to be done with it, and I will attempt to lap the e4400 once more, as carefully as possible to minimize the variation so the whole CPU is sanded by the same paper.
Any thoughts on this? I lapped the CPU first by only going back and forth and not rotating it, and then the second time I tried rotating it 4 times to make sure each side was done evenly.
